I need several network cards that are on the same IP range to talk to services on other IP ranges. I need it since I will connect to bacnet BBMD in different ip ranges.
I do this on a other site with kepware on a windows server. There I have 100 virtual network cards that I can set different BBMD hosts on. Or I can connect with the IP address of the PLC
From the ignition server I can ping every site and have connection.
But when I try to make more network cards on the ignition server (Debian) I can't ping from every network card. And I only get BBMD to work on one card.
I think it's has something to do with the routing table, but I'm not sure.
I made a test server to try to get the right network setup.
Anybody have any tips on what I can do?
caesar@testVMdebian:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: ens18: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether aa:67:27:eb:cc:a9 brd ff:ff:ff:ff:ff:ff
altname enp0s18
inet 10.240.1.206/24 brd 10.240.1.255 scope global dynamic ens18
valid_lft 79869sec preferred_lft 79869sec
inet6 fe80::a867:27ff:feeb:cca9/64 scope link
3: ens19: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether fe:24:26:77:48:94 brd ff:ff:ff:ff:ff:ff
altname enp0s19
inet 10.240.1.212/24 brd 10.240.1.255 scope global dynamic ens19
inet6 fe80::fc24:26ff:fe77:4894/64 scope link
4: ens20: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 4e:7e:d5:a3:6d:44 brd ff:ff:ff:ff:ff:ff
altname enp0s20
inet 192.168.2.105/24 brd 192.168.2.255 scope global dynamic ens20
valid_lft 36736sec preferred_lft 36736sec
inet6 fe80::4c7e:d5ff:fea3:6d44/64 scope link
I tride pinging from the two cards on the same ip range.
caesar@testVMdebian:~$ ping -c 2 10.240.5.10 && ping -I ens18 -c 2 10.240.5.10 && ping -I ens19 -c 2 10.240.5.10
PING 10.240.5.10 (10.240.5.10) 56(84) bytes of data.
64 bytes from 10.240.5.10: icmp_seq=1 ttl=62 time=82.6 ms
64 bytes from 10.240.5.10: icmp_seq=2 ttl=62 time=53.3 ms
--- 10.240.5.10 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1002ms
rtt min/avg/max/mdev = 53.330/67.981/82.632/14.651 ms
PING 10.240.5.10 (10.240.5.10) from 10.240.1.206 ens18: 56(84) bytes of data.
64 bytes from 10.240.5.10: icmp_seq=1 ttl=62 time=60.5 ms
64 bytes from 10.240.5.10: icmp_seq=2 ttl=62 time=63.7 ms
rtt min/avg/max/mdev = 60.473/62.103/63.733/1.630 ms
PING 10.240.5.10 (10.240.5.10) from 10.240.1.212 ens19: 56(84) bytes of data.
2 packets transmitted, 0 received, 100% packet loss, time 1021ms
pipe 2
tshark looking at the packages
caesar@testVMdebian:~$ sudo tshark -i ens19 -f "host 10.240.5.10" --color -c 30
Running as user "root" and group "root". This could be dangerous.
Capturing on 'ens19'
1 0.000000000 fe:24:26:77:48:94 → Broadcast ARP 42 Who has 10.240.5.10? Tell 10.240.1.212
2 1.021185048 fe:24:26:77:48:94 → Broadcast ARP 42 Who has 10.240.5.10? Tell 10.240.1.212
3 2.045175810 fe:24:26:77:48:94 → Broadcast ARP 42 Who has 10.240.5.10? Tell 10.240.1.212
caesar@testVMdebian:~$ sudo tshark -i ens18 -f "host 10.240.5.10" --color -c 30
Capturing on 'ens18'
1 0.000000000 10.240.1.206 → 10.240.5.10 ICMP 98 Echo (ping) request id=0xd1eb, seq=1/256, ttl=64
2 0.082620835 10.240.5.10 → 10.240.1.206 ICMP 98 Echo (ping) reply id=0xd1eb, seq=1/256, ttl=62 (request in 1)
3 1.001739487 10.240.1.206 → 10.240.5.10 ICMP 98 Echo (ping) request id=0xd1eb, seq=2/512, ttl=64
4 1.055058252 10.240.5.10 → 10.240.1.206 ICMP 98 Echo (ping) reply id=0xd1eb, seq=2/512, ttl=62 (request in 3)
5 1.056409916 10.240.1.206 → 10.240.5.10 ICMP 98 Echo (ping) request id=0xe5ea, seq=1/256, ttl=64
6 1.116872579 10.240.5.10 → 10.240.1.206 ICMP 98 Echo (ping) reply id=0xe5ea, seq=1/256, ttl=62 (request in 5)
7 2.058043729 10.240.1.206 → 10.240.5.10 ICMP 98 Echo (ping) request id=0xe5ea, seq=2/512, ttl=64
8 2.121756731 10.240.5.10 → 10.240.1.206 ICMP 98 Echo (ping) reply id=0xe5ea, seq=2/512, ttl=62 (request in 7)
9 2.123445020 fe:24:26:77:48:94 → Broadcast ARP 42 Who has 10.240.5.10? Tell 10.240.1.212
10 3.144559986 fe:24:26:77:48:94 → Broadcast ARP 42 Who has 10.240.5.10? Tell 10.240.1.212
11 4.168562798 fe:24:26:77:48:94 → Broadcast ARP 42 Who has 10.240.5.10? Tell 10.240
The router info
caesar@testVMdebian:~$ routel
target gateway source proto scope dev tbl
default 10.240.1.1 ens18
10.240.1.0/ 24 10.240.1.206 kernel link ens18
192.168.2.0/ 24 192.168.2.105 kernel link ens20
10.240.1.0 broadcast 10.240.1.206 kernel link ens18 local
10.240.1.0 broadcast 10.240.1.212 kernel link ens19 local
10.240.1.206 local 10.240.1.206 kernel host ens18 local
10.240.1.212 local 10.240.1.212 kernel host ens19 local
10.240.1.255 broadcast 10.240.1.206 kernel link ens18 local
10.240.1.255 broadcast 10.240.1.212 kernel link ens19 local
100.68.234.98 local 100.68.234.98 kernel hosttailscale0 local
127.0.0.0 broadcast 127.0.0.1 kernel link lo local
127.0.0.0/ 8 local 127.0.0.1 kernel host lo local
127.0.0.1 local 127.0.0.1 kernel host lo local
127.255.255.255 broadcast 127.0.0.1 kernel link lo local
192.168.2.0 broadcast 192.168.2.105 kernel link ens20 local
192.168.2.105 local 192.168.2.105 kernel host ens20 local
192.168.2.255 broadcast 192.168.2.105 kernel link ens20 local
::1 kernel lo
fe80::/ 64 kernel ens18
fe80::/ 64 kernel ens19
fe80::/ 64 kernel ens20
::1 local kernel lo local
fe80::4c7e:d5ff:fea3:6d44 local kernel ens20 local
fe80::a867:27ff:feeb:cca9 local kernel ens18 local
fe80::fc24:26ff:fe77:4894 local kernel ens19 local
arp info
caesar@testVMdebian:~$ sudo arp -n
Address HWtype HWaddress Flags Mask Iface
10.240.5.10 (incomplete) ens19
10.240.1.1 ether 68:54:ed:00:58:b8 C ens18
192.168.2.1 ether 20:97:27:04:aa:21 C ens20
10.240.1.1 ether 68:54:ed:00:58:b8 C ens19
