Hello everyone,
I'm working on a project where I need to communicate with a new Johnson Controls system that uses Bacnet/SC — the secure/encrypted version of Bacnet.
As far as I know, Ignition doesn't currently support BACnet/SC directly, and it seems that Kepware doesn't support it either.
Has anyone here successfully integrated with BACnet/SC using Ignition?
Any advice, workarounds, or suggested tools would be greatly appreciated!
Thanks in advance!
Andrea
From what I have read, it is a TLS/Websockets layer around Bacnet, so in theory existing drivers could be modified to enable it. Haven't seen it as yet.
Echoing @andrea.minu, we're curious when BACnet/SC will be supported by the Ignition BACnet driver.
Sorry, it's not even planned at this point, so I couldn't answer that. The underlying BACnet library we use doesn't implement it.
Doing a bacnet system right now, albeit not /sc. But why not use a bacnet/sc gateway like AHR 2023: BACnet/SC
Bridges /sc with Bacnet/IP and /MS
Im doing Bacnet at the PLC level using an MAS field server gateway to bridge Bacnet/IP to EIP, then passing the data to Ignition through standard UA drivers.
It looks like a feature request for BACnet/SC support was submitted previously.
