Unfortunately I’ve played around a bit and cannot get the import name out (maybe something to do with the Ignition wrapping)
Here’s what PrettyMap and NameMap give you which unfortunately only make use of the underlying names:
PrettyMap (objects):
{"0":"analog-input","1":"analog-output","2":"analog-value","3":"binary-input","4":"binary-output","5":"binary-value","6":"calendar","7":"command","8":"device","9":"event-enrollment","10":"file","11":"group","12":"loop","13":"multi-state-input","14":"multi-state-output","15":"notification-class","16":"program","17":"schedule","18":"averaging","19":"multi-state-value","20":"trend-log","21":"life-safety-point","22":"life-safety-zone","23":"accumulator","24":"pulse-converter","25":"event-log","26":"global-group","27":"trend-log-multiple","28":"load-control","29":"structured-view","30":"access-door","31":"timer","32":"access-credential","33":"access-point","34":"access-rights","35":"access-user","36":"access-zone","37":"credential-data-input","38":"network-security","39":"bitstring-value","40":"characterstring-value","41":"date-pattern-value","42":"date-value","43":"datetime-pattern-value","44":"datetime-value","45":"integer-value","46":"large-analog-value","47":"octetstring-value","48":"positive-integer-value","49":"time-pattern-value","50":"time-value","51":"notification-forwarder","52":"alert-enrollment","53":"channel","54":"lighting-output","55":"binary-lighting-output","56":"network-port","57":"elevator-group","58":"escalator","59":"lift"}
NameMap:
{"load-control":"load-control","notification-forwarder":"notification-forwarder","access-point":"access-point","averaging":"averaging","multi-state-output":"multi-state-output","channel":"channel","large-analog-value":"large-analog-value","program":"program","life-safety-zone":"life-safety-zone","event-enrollment":"event-enrollment","elevator-group":"elevator-group","analog-output":"analog-output","loop":"loop","datetime-value":"datetime-value","group":"group","access-credential":"access-credential","bitstring-value":"bitstring-value","access-user":"access-user","date-pattern-value":"date-pattern-value","notification-class":"notification-class","life-safety-point":"life-safety-point","structured-view":"structured-view","integer-value":"integer-value","network-security":"network-security","binary-lighting-output":"binary-lighting-output","lift":"lift","accumulator":"accumulator","device":"device","access-rights":"access-rights","datetime-pattern-value":"datetime-pattern-value","binary-output":"binary-output","global-group":"global-group","access-zone":"access-zone","positive-integer-value":"positive-integer-value","trend-log-multiple":"trend-log-multiple","timer":"timer","file":"file","network-port":"network-port","analog-value":"analog-value","binary-input":"binary-input","pulse-converter":"pulse-converter","time-pattern-value":"time-pattern-value","lighting-output":"lighting-output","access-door":"access-door","alert-enrollment":"alert-enrollment","characterstring-value":"characterstring-value","event-log":"event-log","calendar":"calendar","multi-state-input":"multi-state-input","date-value":"date-value","escalator":"escalator","multi-state-value":"multi-state-value","credential-data-input":"credential-data-input","octetstring-value":"octetstring-value","command":"command","schedule":"schedule","time-value":"time-value","binary-value":"binary-value","analog-input":"analog-input","trend-log":"trend-log"}
For now I have stuck with my ‘hacky’ work around - a helper function which adds a hyphen before each capital and then .lower() which isn’t very tidy but is functional… until some release in the future.
