BacnetIP Gateway with BacNet MS/TP Devices
Im trying to connect to devices in my BacNet IP gateway.
i can connect to the gateway itself but cant connect to any other device in the tree.
i can see all of the devices using Yabe .
is there a way to connect to the other devices.
Pics for my Config
successfully connected to the Green (Gateway) but cant connect to the Red .
You need to configure a BACnet device in Ignition for every device in the tree you want to connect to. You typically don't need a connection defined for the gateway device at all.
BACnet gateways basically just move traffic back and forth with a network you can't reach - you aren't actually browsing that device as if it were an aggregator. The YABE UI just makes it appear that way.
Could you please upload a screen shot of a configuration you've used that worked?
(at least 2-3 devices)
Have you ever used that method with Samsung Bacnet DMS ?
that's is exactly what I'm showing. configured a BACnet driver for my device and cant connect.
