Bad encoding from script
Hello!
Using Ignition 7.7.1 x64
I have “Tree view”:
screenshot.su/show.php?img=e4bd8 … 534667.jpg
As you can see, some of “path” has bad encoding. This rows with bad encoding was inserted by script dataset = event.source.parent.getComponent('Tree View') tags = system.tag.browseTagsSimple("Vent/", "ASC") for tag in tags: if tag.name.find("P-") != -1: newRow = ["Приточные установки/",tag.name,"default","color(255,255,255,255)","color(0,0,0,255)","","","","default","color(250,214,138,255)","color(0,0,0,255)","",""] dataset.data = system.dataset.addRow(dataset.data, newRow)
Another rows with good encoding was created directly by hands.
How can i fix this issue?
Try adding u before the string.
newRow = [u"Приточные установки/",tag.name,"default","color(255,255,255,255)","color(0,0,0,255)","","","","default","color(250,214,138,255)","color(0,0,0,255)","",""]
[quote=“jpark”]Try adding u before the string.
I think I tried that before while helping someone else out. Had the same results. I think it has to do with the string sitting inside a list.
I have another idea in mind, but I’ll need some time to sort it out.
I’ll retract what I posted. I don’t know what I was missing from my previous tries, but Jae’s solution will work. :smiley:
Mine looks a bit kludgy, but it also works. Now I’m wondering if it had something to do with the previous Jython version… :scratch:
[code]import codecs
newRow = [codecs.utf_8_decode(“Приточные установки/”)[0],tag.name,“default”,“color(255,255,255,255)”,“color(0,0,0,255)”,"","","",“default”,“color(250,214,138,255)”,“color(0,0,0,255)”,"",""]
[/code]
Thanks! :thumb_left:
