Hello!
I’m new to Ignition, and for my studies, I was asked to continue a project started by someone else.
I’m working with 2 Siemens S7-1500 CPUs and Ignition 8.3.10. I’m using the CPUs' OPC UA server. I’ve used Siemens PLCs before, but I’m not a professional and I’m still learning.
In the project, when I configure my tags in polled mode at any rate, the tag quality goes to Bad_failure. The only way to make them good again is to use subscribed mode.
I checked the CPU configuration in TIA Portal, and the maximum number of monitored items is set to 10000. I have 2 tag providers with 10445 tags each. I disabled the default provider because I don’t use it in my project to unload my CPU. In the client-side OPC UA connection diagnostics details, it shows about 6000 tags for CPU 1 and 5000 tags for CPU 2.
But even with that, if I set my tag to Polled, no matter the rate, they always end up in bad_failure. I haven't touched anything else in the tag group configuration besides the mode and the rate. Can someone help me understand why?
Here, you can find some screenshots of my configuration:
Also, when I want to add tags with browse devices, it doesn't work for my CPU 1 (it worked once, but after that, it takes a long time to load and doesn't show any tags). On the other hand, it works for my CPU 2. Do you have any idea why it doesn't work?
Thank you in advance for your help.
