I may be having a senior moment here, but I’m sure having issues connecting my 7.7.5 install to a 7.5.5 OPC server. Here’s what I have so far. Any ideas are appreciated. And, if you stop by Hudson and fix for me, I’ll even buy lunch!
com.inductiveautomation.opcua.UAException: Bad_NotConnected
com.inductiveautomation.xopc.client.stack.TCPClientChannel.stopIOAndShutdown(TCPClientChannel.java:303)
com.inductiveautomation.xopc.client.stack.TCPClientChannel.notifyChannelError(TCPClientChannel.java:684)
com.inductiveautomation.xopc.common.stack.UAChannel$1.deliver(UAChannel.java:790)
com.inductiveautomation.xopc.common.stack.UAChannel$DeliverToDelegate.run(UAChannel.java:1599)
com.inductiveautomation.xopc.client.stack.SerialExecutionQueue$RunnableExecutor.execute(SerialExecutionQueue.java:100)
com.inductiveautomation.xopc.client.stack.SerialExecutionQueue$RunnableExecutor.execute(SerialExecutionQueue.java:97)
com.inductiveautomation.xopc.client.stack.SerialExecutionQueue$PollAndExecute.run(SerialExecutionQueue.java:75)
java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
java.util.concurrent.FutureTask.run(FutureTask.java:266)
java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)
java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)java.lang.Thread.run(Thread.java:745)
The remote OPC server is running 7.5.5 on Win7 (an old Panel Edition install):
Primary Ignition Server is v7.7.5 on Ubuntu 14.04:
See? Senior moment, I tell you!
