Hello!
I had created a window which root container’s quality was good, but for some reason is now 404. I tried to force the quality but I couldn’t. Why is this happening? How I can set the quality as good again?
Thanks!
Hello!
Thanks!
That means a property on the root container is bound to a tag that doesn’t exist.
In 7.4 you can right click on the component and choose “Run Diagnostics” and it’ll list all of the properties, and their qualities, helping you find what’s causing the overlay.
Thanks for your answers! I was able to find the property bound to the ‘mysterious tag’ by using run diagnostics. The problem was solved.
