When I try to edit some tag values that sit under a UDT within Designer I get an error Bad_ReadOnly popup. I’m puzzled what I’m doing wrong as some tags that sit under the same Edge Nodes but are not under a UDT can be edited (i.e. I can see Ignition issuing a DCMD message over MQTT).
I’m using Ignition + MQTT Engine. I create tags with the Node-RED Sparkplug client.
What can cause this error?
I’m running Ignition 8.1.
Art
