I am trying to access a property on a parent container and the expression keeps returning Bad_Stale.
The expression: {.../this.custom.parameter}
Architecture:
FlexContainer (with desired property)
CoordContainer
Label Component
Not sure why yours is not working but with the same setup I can see and reference custom properties from a parent window
I would make sure the project has been saved since the parameters have been added
If I put the custom property on the view, it works just fine. But when accessing it on the root container it doesn’t work.
