So we're trying to figure out deploying Ignition Edge via Balena. We have a situation where we have the official Ignition Docker image running as one container, and then another container we'd like to pull specific status tags from the Edge OPC-UA server via the internal bridge interface Balena provides. However, when we try to spin up the two containers, we see the following issue:
The following is the error logged during one of these events:
io.netty.handler.codec.DecoderException: UaException: status=Bad_TcpMessageTooLarge, message=max message length exceeded (16777639 > 4128)
at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:499)
at io.netty.handler.codec.ByteToMessageDecoder.channelInputClosed(ByteToMessageDecoder.java:426)
at io.netty.handler.codec.ByteToMessageDecoder.channelInputClosed(ByteToMessageDecoder.java:393)
at io.netty.handler.codec.ByteToMessageDecoder.channelInactive(ByteToMessageDecoder.java:376)
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelInactive(AbstractChannelHandlerContext.java:305)
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelInactive(AbstractChannelHandlerContext.java:281)
at io.netty.channel.AbstractChannelHandlerContext.fireChannelInactive(AbstractChannelHandlerContext.java:274)
at io.netty.channel.DefaultChannelPipeline$HeadContext.channelInactive(DefaultChannelPipeline.java:1405)
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelInactive(AbstractChannelHandlerContext.java:301)
at io.netty.channel.DefaultChannelPipeline.fireChannelInactive(DefaultChannelPipeline.java:901)
at io.netty.channel.AbstractChannel$AbstractUnsafe$7.run(AbstractChannel.java:813)
at io.netty.util.concurrent.AbstractEventExecutor.runTask(AbstractEventExecutor.java:174)
at io.netty.util.concurrent.AbstractEventExecutor.safeExecute(AbstractEventExecutor.java:167)
at io.netty.util.concurrent.SingleThreadEventExecutor.runAllTasks(SingleThreadEventExecutor.java:470)
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:566)
at io.netty.util.concurrent.SingleThreadEventExecutor$4.run(SingleThreadEventExecutor.java:997)
at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74)
Caused by: org.eclipse.milo.opcua.stack.core.UaException: max message length exceeded (16777639 > 4128)
at org.eclipse.milo.opcua.stack.core.channel.headers.HeaderDecoder.getMessageLength(HeaderDecoder.java:39)
at org.eclipse.milo.opcua.stack.server.transport.uasc.UascServerHelloHandler.decode(UascServerHelloHandler.java:102)
at io.netty.handler.codec.ByteToMessageDecoder.decodeRemovalReentryProtection(ByteToMessageDecoder.java:529)
at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:468)
There are no issues when we have Edge and the program running in the same instance (so they both have access to localhost), in that situation we're able to connect to the OPC-UA server no problem. But Ignition really doesn't seem to like Balena's bridge interface; we try to bind the endpoint to Balena's internal service name and it will reject it. Is this a known issue/is there a workaround?
