If you have encountered BAD DATA in FactorySQL when trying to log items from Kepware’s OPC server then here are the steps required to solve this problem:
Click Start -> Run
Type dcomcnfg
Expand Component Services in the left navigation tree
Expand Computers
Right click on My Computer and select properties
Click on the Default Properties tab
The Default Authentication Level should be set to None
Click OK to exit and close the window
Restart machine for settings to take effect
Now data should show up in FactorySQL. If you have any more questions regarding this issue please email us at support@inductiveautomation.com.
Glad to hear it helped you out. I’m curious though, what version of FactorySQL were you using?
As of FactorySQL 2.2, this should no longer be an issue. Therefore, if you were indeed using 2.2, I’d like to know about it. Otherwise, you may want to go download the latest version, just so that you don’t need to do this for every installation you perform. Also, version 2.2 was tested at the latest OPC Interop conference, which included that specific OPC server (the Takebisihi FA-M3).
At any rate, I’m glad that you got it working, and thanks for posting!
