Are there any plans to implement the "Badge Attribute" input for the AD/Internal Hybrid source? I see that it is present for a pure AD user source, but not for the hybrid. We'd really prefer that to be linked fully so that there is no manual maintenance.
No plans currently - I went ahead and created ticket IGN-9059 to track this request.
What we would probably do is add the same Badge Attribute and Badge Search Filter settings that we added in 8.1.25 to the Pure Active Directory user source to the Hybrid source types as well. If those settings are populated, badge authentication is performed against AD, otherwise it is performed against the DB.
Would that work for your use case?
Thank you, and yes that would be perfect.
