Badge login issue when it contain letters
Hello, everyone!
I'm trying to change the way the users do the authentication challenge, changing from username + password method to badge method.
At first, it went well by:
  • Creating an identity provider with "badge" as default but with "username and password" still enable, because I don't want to eliminate this possibility;
  • Using the same user source used before, that is linked with the A/D of the client;
  • Passing this identity provider in the parameter of the authentication challenge call.
I successfully logged in with a random number in a QR code read by a scanner (that will be the mode of reading the badge).
The problem comes when I try to log in users that have letters in the badge. Is there a property or configuration to allow letters in the badge of the users?
The users use this QR Code to access others software programs, and I don't want them to use two badges.
OBS: The scanner is reading good the badges with letters, I tested it in a notepad. I'm using Ignition 8.1.39.
Appreciate if someone could help!
Give support a call or email, they are obligated to respond.
The forum is pretty much a volunteer effort and the majority of users are not IA employees. Sometimes nobody has your answer here.
Ok, doing it right now. Thanks, Kevin!
I've used the badge authentication with letters without issue. Make sure you aren't using a newline character in your string. The newline char is the delimiter used to signal input end.
Badge-based Authentication Support - Ignition Early Access - Inductive Automation Forum
Just for the record:
The issue was solved. I believe is something with the external A/D.
I created an internal user source configured to be the Failover source of the A/D user source and set the failover to "soft". Then, registered the badges in the internal source and it goes ok until now. I don't know yet why the A/D user source don't let me to login when the badges have letters, but for now I assume that the problem wasn't in Ignition.
