I have a difficulty to make a connection using a user id and password to a local Ignition OPC UA server without certificate and private key at now. Both client and Ignition server are running locally at a windows platform.
Here is my code snippet. Can you help me figure out the problem?
void test_Ignition_OPC_UA_Secure_Connection()
static const char* const defaultUrl = "opc.tcp://localhost:62541";
UA_Client* client = UA_Client_new();
UA_ClientConfig* cfg = UA_Client_getConfig(client);
UA_StatusCode status = UA_ClientConfig_setDefault(cfg);
assert(status == UA_STATUSCODE_GOOD);
cfg->securityMode = UA_MESSAGESECURITYMODE_NONE;
status = UA_Client_connectUsername(client, defaultUrl, "cye", "Smash123@1");
assert(status == UA_STATUSCODE_GOOD); // status == BadIdentityTokenRejected
UA_Client_delete(client);
Any change to the Ignition OPC UA server settings required a restart to take effect. If you just now enabled anonymous access go ahead and restart.
edit: ah, oops, you are trying to connect with a username password. the "No matching UserTokenPolicy" in your logs threw me off track.
You must have a certificate and private key configured to connect with a username/password, the password is encrypted before being sent to the server.
Yes, I know the trick. After making a change using localhost:8088, I did restarting the Ignition service.
Could you check my code? What is the error message 'No suitable endpoint found'? What configuration do I have to make?
I have to use certificate, private key, user id and password together for making a connection. If so, could you show me a tutorial site to guide me with detailed steps? How can I encrypt a password? Can you show me some code snippet?
You don't need to encrypt it, the SDK you're using will do it for you.
Try the open62541 client examples if that's the SDK you use: open62541/examples/client_connect.c at 6f2aeaf040b311d04a5561eb3d4e6400b118adbc · open62541/open62541 · GitHub
Or find your own tutorial on Google. I can answer Ignition and OPC UA questions but I'm not going to try to teach you how to use an SDK I've never even used myself.
What is configuration I have to do for certfile.der and keyfile.der? What requirements are for the two files?
