I’m actually facing a problem with the Bar chart component in the 7.7.2 Version of Ignition. When i bind the data property to a SQL query, i have nothing displayed on the chart (as you can see int he attached image). However if i manually create a dataset with the Dataset Viewer it displays it well.
Is it a bug in Ignition or is there a way to bind this property?
