Bar Chart Display Help
I am trying to display 12 tags setpoints in a bar chart. Ideally each bar would represent one of the tags, and would change when the value was changed so that there was a graphical display of each individual setting. I have tried to indirectly bind the data property to each tag, but have not figured out a way to make this work. I’m in search of suggestions! Thanks for any help.
Cell update binding will allow you to bind tag values to individual cells (bar values) in the dataset. Note this applies to the Bar Chart component, not the Easy Chart component.
