Hi, I’m trying to show some columns in a bar chart, I have two columns in a dataset
SELECT sum("total1")as "total1",sum("total2")as "total2" FROM informe
This data is showing ok in a pie chart if I set extract order to by row, but using a bar chart is only showing one column.
If I select three columns is only showing the last two columns, if I select four columns, shows the last three.
