Bar Graph with 2 y-axis
Good morning,
I'm trying to create a page (vision) with BarGraph where I need to implement 2 Y-axis.
It's possible do it?
thanks
Yes.
Have you worked much with the chart component's chart customizer? You can easily add multiple axis, and then use the dataset properties tab to assign one of the bar renderers to each one.
Hi @justinedwards.jle
in chart component I can edit into 'chart configuation' , property AXES, where I can modifie dataset .
but in bar graph i don't see same possibility
Why don't you just use the chart component? It's easy enough to set up with a category axis & renderer to render as a bar graph.
