Goodnight. I came here to ask for your help. I have three historical Boolean tags that inform when the machine is running at high, medium and low speed and starting from the system.tag.queryTagHistory (Duration On) function I have the time that a particular machine is running at different speeds based on the interval of time I spent (startDate: 7 a.m endDate: Now (6000)). The idea would be to create a bar to inform, over time, the fluctuation of the time the machine is running at each speed. As shown in the figure below:
The idea is to create just one bar, in the image there are two just to symbolize the fluctuation of each speed as time passes. I tried but I ran out of attempts. Actually, I don’t even know if it’s possible, but I would like to know on the forum because there is a lot of knowledge here.
I don’t know if I managed to be clear on the question, but thank you in advance.
