Did anyone try to connect with this controller ? By ethernet (TCP/IP)
Harwarde descr. bellow:
eurotherm.com/products/machi … -retrofit/
Any success ?
Any success ?
I’m not sure about the current conversion that you reference in the link, but I have experience with the original MACO 6500 & 8000 conversion that consisted of a Schneider Quantum PLC coupled to the BC controller and new I/O. This was usually integrated with Wonderware. At the time I worked with this, it was Wonderware 7 or 8.
That being said, I am sure one can utilize the UA OPC server to grab the data from the MACOs updated PLC.
This is a rather old post. But lets see if I can be of assistance or if you ever got this working with Ignition.
I checked out the link you had in your post. It looks like a Siemens controller may be used in this application. What Siemens controller is used in this application?
