I am attempting to send a string to a barcode printer. I found two scripts, at the end of this post, on the forum.
The first successfully prints the barcode the first time it is run, but does nothing the second time it runs. Restarting the printer allows printing one more barcode.
The second script does not do anything; no errors, no printer output.
If anyone can tell me how to get script 1 to print labels each time it runs, or how to get script 2 to work at all, or has a better solution, I would be very grateful!!!
Script 1---------------------------------------
strMessage="""
P
E2;F2
H0;o5,5;d3,PART NUMBER FORMAT
B1;o10,10;i1;d0,13
R
E2
F1123
Import Socket Library
import socket
Get Printer IP and Port
strIP = ‘192.168.123.87’
port=9100
Send Data to Printer
updSocket=socket.socket(socket.AF_INET,socket.SOCK_STREAM)
updSocket.connect((strIP,port))
updSocket.sendall(strMessage)
updSocket.close
Script 2---------------------------------------
strMessage="""
P
E2;F2
B1;o10,10;i1;d0,13
R
E2
F1123
import socket
port=9100
import system
udpSocket=socket.socket(socket.AF_INET,socket.SOCK_DGRAM)
udpSocket.sendto(strMessage,(strIP,port))
