Barcode scan to fill multiple text fields
I have a popup window that has three text fields (catalog#, lot#, and serial#). I want to be able to fill all those fields at once upon scanning a barcode without the need to click into the text fields. Any ideas on how to do so? Anything is appreciated. (Ignition Version 8.0.10)
I recommend the barcode module from sepasoft.
https://www.sepasoft.com/products/barcode-scanner/
Setting focus as you need may help.
https://docs.inductiveautomation.com/display/DOC80/Focus+Manipulation
