Barcode Scanner Input - Variable Length
I have been using the Barcode Scanner Input on a Perspective view for almost 18 months with good success. It is reading a scanned barcode and send the value to a Transaction Group to grab information. I am using a regex code ([0-9]{7})$ to grab the 7 numeric digits of the scan.
However, now we are starting to have a mix of 7 and 8 digit barcodes. I have attempted to modify the regex code like this - ([0-9]{7,8})$ and ([0-9]{7,})$ - and it only returns 7 digits no matter what the length of the code. I am afraid that if I change to this - ([0-9]{8})$ - 7 digit barcodes will not work.
View the reader output in Notepad, I see that it appears to be appending an ENTER or new line suffix. There is no prefix. I thought that I could use that in the suffix field and get rid of the regex code but that does not appear to be working. I very well could be entering the format of suffix wrong. Because it is looking for a string, I created a simple expression binding for CHR(10). Is a prefix character required?
Any help would be greatly appreciated.
You should be able to use a suffix character that the browser won't automatically interpret. Perhaps the Pipe | character.
(Variable length codes typically need unambiguous suffix codes when using keyboard wedge input modes. Which is all Perspective can do when the scan is not built into a mobile device.)
I remember Perspective handles "Enter" a little differently from what one might expect, try \n:
But honestly it would be better if you can change the scanner to output a different suffix as per Phil, to avoid keyboard getting picked up as a scan.
