We are looking to scan the barcode using ignition barcode scanner module but we dont know which barcode scanner is compatible with Ignition SCADA. if anyone has done previously, let me know for the same.
Also i am not able to print the barcode in Vision client, so need some help on this also.
The barcode formats listed on their website should help indicate what devices would be supported. A script could then be setup to print the data returned.
