Hello,
For the life of me I cannot figure out how to get the barcode scanner input to work.
It is working with the prefix and suffix, and I am accumulating values on the screen inside the barcode filed, however I cannot figure out how to write any of those values into another tag for the PLC to see that input.
It would be a massive help if someone could help me figure out how to do this.
Thanks!
Are you using the Sepasoft Barcode Scanner Module for Vision?
I should have been more clear… Sorry for that…
I am using the built in Barcode Scanner Input component for Perspective
Also to add, it is working fantastic following the tutorial when using a mobile phone. It is able to update the tag and everything.
The problem is I cannot get it to work with the one designed for a actual barcode scanner that is giving text inputs.
I’m not very familiar with perspective yet, so I can’t really say much. Hopefully, someone else will chime in.
