Basic Request Cycle
Hello There,
I have a gateway log filled with this :
Its an Siemens 1500 CPU.
Does anyone have familiarity with something similar?
Thanks so much in advance
If you click the "+" to expand the message what does it say under there?
I think I may have seen a bug like this in the past when invalid/unparseable addresses made their way to the driver, but I'm not sure. You may have to work with support to get your logs and check addresses.
It's just a null pointer exception.
Sure
You'll need to update the ignition.conf file to capture a useful stack trace from the repeated exception:
Support can help you with that process, as well.
I see, I'll set this up in weekend and will watch next week for the details.
Thank you @paul-griffith , @Kevin.Herron
Hello @paul-griffith ,
I did updated ignition conf file and restarted the server. I still do get this errors without much of a stack.
That's a much more helpful stack trace. I expect @Kevin.Herron to pop in any moment with new bug number assigned. (:
Yes, looks like a bug I can make a ticket for.
You've probably got a script somewhere that is trying to write a null value. You'll have to figure out where that is and fix it for now.
hmm, makes sense.
Thanks Kevin
