Best practice question - writing current timestamp to SQL database
Wondering if there is any significant distinction between the following methods of recording a timestamp while creating a database record:
  • Using Ignition's system.date.now() function, then inserting that value
  • Using the database's CURRENT_TIMESTAMP function (assuming Microsoft SQL Server)
Example of first one:
partNum = '555AB'
now = system.date.now()
query = """INSERT INTO Orders
(PartNum,InsertedOn) VALUES(?,?)"""
args = [partNum,now]
system.db.runPrepUpdate(query,args,'MyDbConnection')
Example of second one:
partNum = '555AB'
(PartNum,InsertedOn) VALUES(?,CURRENT_TIMESTAMP)"""
args = [partNum]
Is it even worth splitting hairs over?
I usually just let the db do the creation date.
I would personally go with option two.
I would also recommend instead of writing raw queries create all your queries inside of named queries. It's a better practice and it will help you/anyone else behind you who may need to edit this application down the road. I've seen many projects where I have to dig and dig to find out that the queries are all raw queries while named queries you know where they are and what they are.
CURRENT_TIMESTAMP is from the database machine's clock. system.date.now() is from the Ignition machine's clock. Which one is right for your application?
