Best practices to manage Alarm array
I have array tag from Opc . This array tag maintained All machine alarms. Each bit give a description meaning for alarm.
What’s the best way to use the alarm module with Array tags.
I have 2100 alarms in one array tag each alarm bit with description.
Is there any way to add these descriptions in simple way?
Chances are you will need to use a UDT, or script the creation of tags with alarms. Obviously UDT would be easiest if plausible. But don't know your situation enough to confirm.
