Best way to import Geo data from ArcGIS to Perspective map
Hello
I want to know possible ways to import and show Geo Data from ArcGIS database in perspective map.
And when concerning for performance is it best to show data in JeoJSON property or a combination of vector property(polygons, polylines, rec, circle) in map component. I want to know for large amount of data which one is best.
Thanks.
Did you find an answer to this? I’m planning a project that will need to display maps and feature layers from Arcgis online, so have been asking similar questions.
I’ve been looking at using the Esri Leaflet library, but am not sure that is the right way to go?
You can use wms layer from arcgis for your tile and it has rest API to get data like features, but you need to ask IT department to do that for you
