We have 2 versions of the same thing working OK. Which one do you think will perform best? We'll have 1000 tags with the same logic executing on a single gateway.
- Using the tag() function and building the relative tagpath dynamically, based on another tag's value
tag(concat("[.]../PM", numberFormat({[.]SELECTOR}, "000"), "/VALUE"))
- Using the case() function and pointing to the corresponding tag (with {}), based on another tag's value.
case({[.]SELECTOR},
1, {[.]../PM001/VALUE},
2, {[.]../PM002/VALUE},
3, {[.]../PM003/VALUE},
0
Neither. Use an intermediate custom string property with an expression like:
Then, on the target property, use indirect tag binding with an base expression like so:
[.]../PM{1}/VALUE
and the indirect {1} pointing to the custom string property.
You should never use the tag() expression function (it is for backwards compatibility). The case() expression would work, but I believe it evaluates all of its expressions, whether used or not. That can result in extra tag value traffic.
UPDATE: I just realized you want to do this with an expression tag. If you must, use your form #1. Or even better, don’t make expression tags. Just build the logic I’ve shown into your client app.
