I have a dataset like this:
{"VALUE1":"","VALUE2":""...},
What is the best way of removing a column?
[i.pop("VALUE1") for i in dataset]
or
#pseudo-code
dataset = system.dataset.toDataSet(headers, data)
dataset = system.dataset.filterColumns(!"VALUE2")
dataset = to.json.dataset(dataset)
FYI: wanna delete that column only if is entirely empty (that's my current objective).
Thanks for the help!
Ended up doing this:
if not any([i.get("VALUE2") for i in value]):
value = [i.pop("VALUE2") for i in value]
Note that this is an inherently inefficient operation that's burning a lot of CPU to run through the list of rows ~twice. Depending on what else you need to do with this data, it might be worth reorganizing to have a single list-per-column in a dictionary per column name, and only 'translate' to this row-wise data structure at the end.
I thought about that, but I ended doing something a bit different.
I used this:
And did this:
self.props.columns[6].visible = any(value.getColumnAsList(value.getColumnIndex("VALUE2")))
So only I show it if there is something to show. A bit different approach than what I first thought. Also this only gets executed at the start of the view. So even if it's a bit inefficient is only done 1 time.
This sound like an XY problem
