Good Morning.
I would like to update Ignition from version 8.0.14 to 8.1.9.
Which of these options is the best?
a) Make backup, uninstall Ignition 8.0.14, install 8.19 and recover backup.
b) Simply install 8.1.9 over 8.0.14
Kind regards.
Good Morning.
Kind regards.
c) make backup, install 8.1.9 over 8.0.14.
Going from 8.0 to 8.1 should be pretty painless. The backup is in case-- for whatever reason-- you need to go back to 8.0.x
ok thanks, but option a) should work without problems or is it not convenient to do so?
it goes faster if you just install over it^^
also you might need to update a lincence i have heard somewhere, but idk much about that
You can, but IMO, it's not really necessary. 7.9 to 8.0, though was a different story. ![]()
