Well, there is a new function system.tag.getTagValues that allows you to read multiple tags at once. It will be faster than doing individual tag reads. It just takes a list of tag paths.
at org.python.core.Py.NameError(Py.java)
at org.python.core.PyFrame.getglobal(PyFrame.java)
at org.python.pycode._pyx30.f$1(<event:propertyChange>)
at org.python.pycode._pyx30.call_function(<event:propertyChange>)
at org.python.core.PyTableCode.call(PyTableCode.java)
at org.python.core.PyFunction.__call__(PyFunction.java)
at org.python.core.PyObject.__call__(PyObject.java)
at org.python.core.__builtin__.map(__builtin__.java)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java)
at org.python.pycode._pyx30.f$0(<event:propertyChange>:13)
at org.python.core.PyCode.call(PyCode.java)
at org.python.core.Py.runCode(Py.java)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:394)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:139)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:247)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:55)
at $Proxy2.propertyChange(Unknown Source)
at java.beans.PropertyChangeSupport.firePropertyChange(Unknown Source)
at java.awt.Component.firePropertyChange(Unknown Source)
at com.inductiveautomation.vision.api.client.components.model.AbstractVisionPanel.fireDynChange(AbstractVisionPanel.java:128)
at com.inductiveautomation.factorypmi.application.binding.util.DynamicPropertyUtil.setPropertyValue(DynamicPropertyUtil.java:217)
at com.inductiveautomation.vision.api.client.components.model.AbstractVisionPanel.setPropertyValue(AbstractVisionPanel.java:112)
at com.inductiveautomation.factorypmi.application.script.PyComponentWrapper.__setattr__(PyComponentWrapper.java:68)
at org.python.pycode._pyx7.f$0(<event:mouseClicked>:1)
at org.python.pycode._pyx7.call_function(<event:mouseClicked>)
at $Proxy1.mouseClicked(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$000(Unknown Source)
at java.awt.EventQueue$1.run(Unknown Source)
at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$2.run(Unknown Source)
Ignition v7.2.11-beta1 (b209)
Java: Sun Microsystems Inc. 1.6.0_26
[/code]
Ive tried a few things but cant seem to figure out what is wrong here.
at org.python.pycode._pyx3.f$1(<event:propertyChange>)
at org.python.pycode._pyx3.call_function(<event:propertyChange>)
at org.python.pycode._pyx3.f$0(<event:propertyChange>:13)
at org.python.pycode._pyx2.f$0(<event:mouseClicked>:1)
at org.python.pycode._pyx2.call_function(<event:mouseClicked>)
Java: Sun Microsystems Inc. 1.6.0_23
[/code]
Not sure exactly where the problem lies. Try replacing the line with the lambda with this one:tagPaths = ["%scurr_throughput"%tagPath, "%stoday_throughput"%tagPath, "%sPrimaryInterval"%tagPath, "%scurr_goodscans"%tagPath, "%scurr_failedscans"%tagPath]Does that work or do you get the same error?
It does allow the script to run, but I am not sure that it is making a big difference in time. I went ahead and changed it to only grab 1 tag instead of 5 different tags just to track the time difference without having to wait as long and it seems to only make about a 10 second difference.
to run the script for 465 total tags using the getTagValue method it took 70 seconds
to run the script for 465 total tags using the getTagValues method it took 60 seconds
That is because you are calling the system.tag.getTagValues function 465 / 5 = 93 times. You want to only call the function a few times. You can modify the code like this:[code]query = “SELECT name, identifier from sbutest”
if event.propertyName in [“devices”, “refresh”]:
table = event.source.getComponent(‘Table’)
newData = []
header = [“Displayname”, “Identifier”, “Current Throughput”, “Today’s Throughput”, “devicestate”, “good polls”, “bad polls”]
res = system.db.runQuery(query)
tagPaths = []
