I had an intern working on a project and the intern mentioned that something flashed in the left bottom corner of the designer screen but was not sure if anything changed.
I decided to investigate a little.
I have found that if you somehow accidentally hit ctrl+x you can “cut” a tag out of the tag browser with no warning. If you try to move or delete a tag you get a pop up making you aware of your potential mistake. It would be nice to see this functionality added to ctrl+x “cut”. Happy Programming.
Running Ignition 7.9
