Host Ubuntu 9.04 server x86
1756-ENBT in slot 1> 1756-L63 in slot 3
When I try the quick client, i get the following error.
1/27/10 1:38:01 PM SROPCServerImpl - Error during browse.
The device shows connected, but I cant browse.
Kyle,
If you look in the log (Configure > Console > Log Viewer) are there any other errors before/after the “Error during browse.” one?
Specifically, there should be one that says "Error during browse operation: " followed by a message.
[code] 1/27/10 3:11:37 PM QuickClientSubscriptionManager - Unsubscribing abandoned quick client subscription: Subscript…
1/27/10 3:10:53 PM DefaultSRRemoteServer - Sending transfer request
1/27/10 3:10:53 PM TCPServerChannel - User admin ([Administrator]) connected.
1/27/10 3:10:53 PM TCPChannelBase - Initialized with security policy: Basic128Rsa15
1/27/10 3:10:53 PM TCPServerChannel - A new TCPServerChannel has connected.
1/27/10 3:10:53 PM TCPServerChannel - Connection was closed.
1/27/10 3:10:53 PM TCPServerChannel - Error decoding UserNameIdentityToken.
1/27/10 3:10:53 PM TCPChannelBase - Initialized with security policy: None
1/27/10 3:10:53 PM TCPChannel - Opening connection to opc.tcp://localhost:4096/iaopcua to re…
1/27/10 3:10:53 PM SROPCServerImpl - SROPCServer is reconnecting…
1/27/10 3:10:51 PM TCPChannelBase - Initialized with security policy: Basic128Rsa15
1/27/10 3:10:51 PM TCPServerChannel - A new TCPServerChannel has connected.
1/27/10 3:10:51 PM TCPServerChannel - Connection was closed.
1/27/10 3:10:51 PM TCPChannel - Channel disconnected. Reconnecting in 0 seconds
1/27/10 3:10:51 PM TCPChannel - Channel Error. Unknown Request Id: 7
1/27/10 3:10:51 PM DeviceImpl - Browsing address “(null)null” on device “SlaveLake” timed ou…
1/27/10 3:08:21 PM Logger - open end
1/27/10 3:08:21 PM Logger - open start
1/27/10 3:08:21 PM Logger - Successfully backed up instance ‘settings’ to '/opt/ignition…
1/27/10 3:08:20 PM Logger - Initiating backup of instance ‘settings’
1/27/10 3:08:20 PM Logger - DataFileCache.close() : close
1/27/10 3:08:20 PM Logger - DataFileCache.close() : save data
1/27/10 3:08:20 PM Logger - DataFileCache.close(true) : start
1/27/10 3:08:20 PM Logger - Checkpoint end
1/27/10 3:08:20 PM Logger - defrag end
1/27/10 3:08:20 PM Logger - open end
1/27/10 3:08:20 PM Logger - open start
1/27/10 3:08:20 PM Logger - DataFileCache.close(false) : start
1/27/10 3:08:20 PM Logger - defrag start
1/27/10 3:08:20 PM Logger - Checkpoint start
1/27/10 3:07:51 PM SROPCServerImpl - Error during browse.
1/27/10 3:06:29 PM PropertiesFactory - Loading properties files from jar:file:/opt/ignition/tomcat/…
1/27/10 3:05:58 PM RequestListenerInterface - registered listener interface [RequestListenerInterface name…
1/27/10 3:03:28 PM DefaultSRRemoteServer - Sending transfer request
1/27/10 3:03:28 PM TCPServerChannel - User admin ([Administrator]) connected.
1/27/10 3:03:28 PM TCPChannelBase - Initialized with security policy: Basic128Rsa15
1/27/10 3:03:28 PM TCPServerChannel - A new TCPServerChannel has connected.
1/27/10 3:03:28 PM TCPServerChannel - Connection was closed.
1/27/10 3:03:28 PM TCPChannelBase - Initialized with security policy: None
1/27/10 3:03:27 PM TCPServerChannel - A new TCPServerChannel has connected.
1/27/10 3:03:27 PM TCPChannelBase - Initialized with security policy: None
1/27/10 3:03:27 PM TCPChannel - Opening connection to opc.tcp://localhost:4096/iaopcua to re…
1/27/10 3:03:27 PM SROPCServerImpl - SROPCServer is reconnecting…
1/27/10 3:03:24 PM SRContext - Ignition["/main", state=STARTING] ContextState = RUNNING
1/27/10 3:03:24 PM ClusterManagerImpl - ClusterState = MASTER
1/27/10 3:03:24 PM ModuleManagerImpl - Starting up module fpmi
1/27/10 3:03:24 PM ModuleManagerImpl - Starting up module help
1/27/10 3:03:24 PM ModuleManagerImpl - Starting up module fsql
1/27/10 3:03:24 PM ModuleManagerImpl - Starting up module rept
1/27/10 3:03:24 PM ModuleHook - OPC-COM module will not start - can only run on Microsoft Wi…
1/27/10 3:03:24 PM ModuleManagerImpl - Starting up module opccom
1/27/10 3:03:24 PM ModuleManagerImpl - Starting up module xopc-drivers
1/27/10 3:03:24 PM XOPCModule - Done.
1/27/10 3:03:24 PM XOPCModule - Attempting to add port 4096…
1/27/10 3:03:24 PM XOPCAddressSpace - Parsed 1980 nodes.
1/27/10 3:03:22 PM XOPCGatewayHook - OPC-UA module starting up.
1/27/10 3:03:22 PM SROPCServerImpl - Trial expired. Setting nodes to BAD_TRIAL_TIMEOUT.
1/27/10 3:03:22 PM ModuleManagerImpl - Starting up module xopc
1/27/10 3:03:22 PM ModuleManagerImpl - Trial time reset. Time remaining = 0. Notify modules = fal…
1/27/10 3:03:22 PM ModuleManagerImpl - Starting up…
1/27/10 3:03:22 PM GatewaySessionManagerImpl - Starting up…
1/27/10 3:03:22 PM ProjectManagerImpl - ProjectManager starting up…
1/27/10 3:03:22 PM AlertNotificationManagerImpl - Starting up…
1/27/10 3:03:22 PM AlertStorageManagerImpl - Starting up…
1/27/10 3:03:22 PM InternalSQLTagsProvider[default] - Starting tag provider ‘default’.
1/27/10 3:03:22 PM TCPChannel - Opening connection to opc.tcp://localhost:4096/iaopcua to re…
1/27/10 3:03:22 PM SROPCServerImpl - SROPCServer is reconnecting…
1/27/10 3:03:22 PM InternalProviderSettingsRecord - Default datasource not found for internal tag provider "defa…
[/code]
Whats the status on this issue? Is Tom in today?
We have a ENBT module coming so that we can do in house testing. In the mean time, is it possible to get VPN access to the your ENBT module. If not, you can turn on Trace level logging for the ControlLogixDrive in the console, add the device then send me the wrapper.log file.
Steps
Thank you,
Tom
I sent you connection information, call me when you get in please.
