When I try to do bidirectional Binding of the EasyChart Axes to a client dataset , I can see that the bidirection checkbox is greyed out. It is possible to bidirectional bind to a property.
When I bind to a internal template property, the dataset is not always updated. Is this a restriction or a bug? What Can I do to inspect the automatically created axes when a tag is dropped on the chart?
Beware! There be dragons! Specifically, it is easy to make infinite recursion that way. I would suggest not binding at all. Simply use the propertyChange event to process the tagPens dataset for whatever actions you need when new tags are plotted.
