Hi guys. I’m looking for some ideas on how to do the following: I want to be able to change the fill paint of a simple drawed object based on a historical stored integer value. I’m thinking maybe to pick a interval of the historical values for this tag and iterate through the dataset and use the current value for the fill paint property. Any help appreciated
Hi!
Just so I’m clear, are you looking to do something similar to the Status Chart? Or am I missing something? (entirely possible!
Not quite as the status chart. Consider another example: Let’s say i have a multistate indicator that changes over time based on a realtime tag. The tag is also being logged to the historical sql database. Now lets say i want to look how this indicator has been acting the last 5 minutes. (based on the historical data) kinda like a replay function. I guess this probably needs to be done with some more advanced scripting? or maybe there is a fancy way to step through a historical table and bind the current value to the multistate indicator…
