I found something very close yet so different in the search.
I have 7 values for my dropdown showing the labels that I want
I want to change a tag with that.
I thought I could use a script like
system.writeblocking([{New Tag}],[value])
however, I am not actually sure where I could put that on the input to make it apply the value to the tag
I am also not sure if I can use the curly brackets for a tag path like that because in the past for the system.writeblocking(), I had used relative addressing ["[.]newtag"]
I pointed the image and a label at the property value of the input dropdown
for testing purposes, this works great
Monday though, I have find out how to have a tag look at this property to get it’s value
I think I set it as a reference value and can point at the prop value somehow.
Or else I will have to write a script that writes the prop value to the tag.
I thought I saw this in a video though, so I might be able to find out from the videos on Monday.
