Binding directly to a Alarm in a tag
Hi
Im trying to bind directly between a Tag Alarm delay and an Numeric input.
As you can see in the image i can link the Setpoint to the numeric input window via "[default]tgewvds/test/Alarms/Alarm.SetpointA" ,
but i also want to link the Deadband and the Active Delay, are that possieble directly or do i have to use a external binding tag(OPC or Memory ) ?
I cant see the delay and deadband in the list.
I have found the tag for the Deadband.
[default]tgewvds/test/Alarms/Alarm.Deadband"
But what are the tag for Active Delay ?, i have tried what i can come up with.
Active Delay
timeOnDelaySeconds
The time, in seconds, before the alarm will be considered truly active after the active condition becomes true. Also known as a "rising edge time deadband".
