OS: Windows 7 Enterprise
Ignition: 7.3.1 (b496)
Java: 1.6.0_23
What I’m trying to do is create a chart to display historical temperature data from one (out of many) furnaces. Rather than create one chart per furnace, I would like to create one chart that can dynamically display the data for any one furnace at a time. From the Ignition documentation and my searches in this Forum, keeping the pen names in a SQL database and then linking them to the Easy Chart ‘Tag Names’ dataset seems like a good way to achieve this.
I’ve created a SQL database that lists each furnace along with its SQLtag names and a Group name (for organizing the pens in Easy Chart):
MachineNumber TagName GroupName
9563 Pre Heat 1 grp_Pre_Heat
9563 Pre Heat 2 grp_Pre_Heat
9563 Pre Heat 3 grp_Pre_Heat
9563 High Heat 1 grp_High_Heat
9563 High Heat 2 grp_High_Heat
9563 High Heat 3 grp_High_Heat
10006 RBO grp_Pre_Heat
10006 Zone 1 grp_Pre_Heat
10006 Zone 2 grp_High_Heat
10006 Zone 3 grp_High_Heat
10006 Zone 4 grp_High_Heat
The SQLTag names are of the form MachineNumber/TagName. The question I have is what is the best method to transfer or bind the MachineNumber/TagName to the TAG_PATH column of the ‘Tag Names’ dataset?
I think that I could achieve this with Python by copying, replacing, and copying back the ‘Tag Name’ dataset, but it seems like there should be an easier method.
