Each indicator instantiates the same view and the tag paths for both Setpoints and Configuration indicators are bound to the same property in the embedded view. However, the Configuration tag paths will often bind to the default value, seemingly before the tag path is passed as an input parameter to the view. The Setpoint indicators' tag paths are set to persistent and the Configuration indicators' tag paths will do this regardless of persistence setting. What am I missing or what should be my next steps in investigating this issue?
