I’m getting an error when I try to bind the Alert History Function to the Data of a table. It is just a Error box without message or details. (see attachment)
I created the alert storage profile and I can see the alert table with data in the DB.
Binding Error.pdf (108 KB)
Add a Start and End Date.
EDIT: Sorry, I have seen this error before in 7.3 I believe. I recreated it in 7.5 tonight. The output console gives the error:
“ERROR [ExtensibleBindingConfigurator-AWT-EventQueue-0]”, but the message does not say anything.
Adding the Start and End dates should fix the issue.
Cheers,
Chris
Adding the Start and End dates did fix the problem.
Thanks.
