Binding History Enabled in UDT to another tag in UDT
I have a UDT with multiple tags that I’m recording. I would like to have these tags only recorded when a “Connected” tag is set to true inside of the UDT.
Can I bind the tag value within the UDT to the History Enable property of the tags I want to record history on?
tag(stringformat(’%s/Connected’, {PathToTag}[.])
Each instance of the UDT is for a different device that is connected at different points of our process. They are connected with a PLC in the middle, so ignition doesn’t connect to the devices directly. Otherwise I just wouldn’t record the bad statuses.
I would like to avoid having 100s of different Driven Scan Classes, one for each device.
My other idea is to just have a script record the data and avoid tag historian all together.
Have you considered a triggered transaction group for this use case?
Transaction groups are often the ideal solution when the situation is similar to: “X data needs to be stored at rate Y when tag Z is true”
A triggered group would specifically only record data when a certain tag condition is met. For your case the trigger would be when the “Connected” tag is True.
When the device is connected, I would like the value to continuously be recorded, which I guess I could do with enable/disable of the transaction group. I feel like then I’m choosing between 100s of transaction groups or scan groups.
I might be able to just do the tag history as ‘On Change’. They’re environmental sensors so they wouldn’t hold a value for very long.
With a triggered transaction group the data storage would be driven by the device’s “connected” tag, but it would require making a different group for each device.
If the value of the tag will be consistently changing when the device is connected, then the ‘On Change’ history option should work.
Consider using an expression tag that forces bad quality when Connected is false. Then enable history on the expression instead of the base tag.
