I’ve tried to pull in the associated y-value from an xTrace value on the time series chart and power chart to bind to an indicator (i.e. simple gauge) - have not had any success yet.
Does anyone know of a way to get the y-value’s that are displayed in the infobox on either of these charts?
The TimeSeries component X-axis is (date)time as suggested by its title. The xTrace.value property should return the value of the X-axis and since this is a datetime it must return a datetime value.
What were you expecting or hoping for? Were you hoping for the Y-value? I don’t think that’s available. The charts are developed by AMCharts so you might find some documentation on their site. (I couldn’t.)
I’m not sure what version you have, so perhaps yours is different. I am currently on 8.1.14 and when the chart is in X-Trace Mode there is an X-Trace Object added to the Interaction Property. In that object you will find a Values array which has the Y-Value for that X-Trace.
In theory you could bind to that, however, you will need to Coalesce it, because there will absolutely be times when there are no X-Traces on the chart. This is for the power chart, I don’t know about the Timeseries chart.
I took a look at the values array under X-Trace, it seems to just be a number between 0-1, based on the distance of the x-trace line from the y-axis (0 close to the y-axis, 1 farthest away).
