Bit name in a report
Hello everyone, I am working in a report and I want to put the name or label of the alarm in the report, the alarms are in bites. in the report the alarm appears as a event value
Thanks for your help.
BR
You can do it by querying the data in such a way that it appears with the labels you want. If you have a table that has labels per value, you can achieve this with a join. Otherwise you may want to use a case statement.
Hello Thanks for your reply, I did this in report design and works :
@y_alarms==4?“Door Open”:(y_alarms==-32764?“Low Temperature”:" "
BR
