Here’s the situation:
I have a copy of Ignition Gateway running on an internal office network.
I have a copy of Ignition Gateway running on an AWS EC2 instance that I can connect to.
When I launch a client or the designer from the AWS instance, the resolution is noticeably bigger. The whole screen does not show as it does if I launch the copy off of my internal network, instead everything is bigger and I get scroll bars. I checked the resolution in the designer in both copies of the application and they were the same as expect, but for some reason it keeps loading at a higher resolution. Does anyone have any idea why this could be happening? I’m at a complete loss.
