I have a CSV file I am trying to import form a legacy project. Has about 25000 tags in it, and when I import, it gives me the following error.
Host is Ubuntu 9.10, 64 Bit
Java 1.6 u 15 i think
com.inductiveautomation.ignition.designer.sqltags.action.ImportTagAction$ImportException: Error on row 5: Cannot coerce value '[false,GOOD_DATA]' into type: class java.lang.Boolean
at com.inductiveautomation.ignition.designer.sqltags.action.ImportTagAction$CSVTagImporter.run(ImportTagAction.java:163)
at com.inductiveautomation.ignition.client.util.gui.ProgressDialog$TaskRunner.run(ProgressDialog.java:208)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.ClassCastException: Cannot coerce value '[false,GOOD_DATA]' into type: class java.lang.Boolean
at com.inductiveautomation.ignition.common.TypeUtilities.coerce(TypeUtilities.java:818)
at com.inductiveautomation.ignition.common.sqltags.TagDefinition.setAttribute(TagDefinition.java:257)
at com.inductiveautomation.ignition.designer.sqltags.action.ImportTagAction$CSVTagImporter.tagFromRow(ImportTagAction.java:241)
at com.inductiveautomation.ignition.designer.sqltags.action.ImportTagAction$CSVTagImporter.run(ImportTagAction.java:145)
... 2 more
Ignition v7.0.2 (b4482)
Java: Sun Microsystems Inc. 1.6.0_17
