So… I just blew away my SQL tags by accident. Anyway I can do a partial restore from backup?
No, you can restore the backup on another machine and just export / import your tags through CSV.
Easy enough, thanks for the reply.
Now, Before I go pull the tapes to grab last weeks backup, Can I use the autodb backup I see Ignition saved for this?
Yes. You just have to unzip one of the auto-backups and place it in a db folder in another installation. Make sure Ignition is stopped, unzip it and then start Ignition up and your project should be there.
Thanks for the help!
That was almost trivial to recover from. Didn’t even have to shut the system down.
