I am experimenting with Block Groups and am trying to use Ignition to filter records from a table by passing WHERE conditions from the PLC. The selected values are then mapped back to the PLC.
It seems to basically work except once a value is set in the Latched Value field, I cannot clear. it.
For instance, if I trigger the group and the WHERE clause returns 6 values, the Latched and Source Values are correct. But if I then change the conditions so that only 1 value is returned and retrigger, the result is placed in position 0 but the other 5 values are retained from the previous query.
I can clear the Source Values by writing them in the PLC before triggering the group but the latched values just come back.
I found the section in the help about “Setting NULL DB Values to Default”, but whichever options I check, the group behaves the same.
Any help will be greatly appreciated!
